I replaced the bulkhead on my SNS Noise source, the service manual states that the current needs to be set using a SNS Service software however there is no part# listed and it doesnt seem to be part of the NFA Service sw i got, anyone has any idea where to get this SW ?
It not only takes software that you are referring to, but also an investment in the recommended test equipment from Agilent. I recommend you have the noise source calibrated by Agilent to make sure it is done right.
Regards -
