I'm trying to run a self test on the E5505A using c code in a LabWindows environment. I'm able to initialize the the E5505A but can't run the self test. The only way it seems to work is if I initialize and run the self test, let it fail, and then step into the code and run the self test again, which assigns it a new handle and it decides to pass.
Any ideas on why I have to run the self test twice for it to pass?
Thank you for all the help in advance,
AhsanA
AhsanA
We would like to try to help you. Please send me your C source code.
Thanks -
