When measuring the 3dB BW of an FM signal, does one choose the points 3dB below the center frequency, or the points 3dB below the peaks? In a high FM deviation signal, the center frequency is suppressed and the tallest points are closer to the edges of the band. In the attached spectrum, do I use the pink points or the green points to measure my 3dB BW?
Thanks for your help,
Helen
Helen
