Hi All,
I try to upgrade N9010A firmware from A.01.50 to A.07.06, I followed the instructions and completed the update without any error as in the update instruction(http://sa.tm.agilent.com/XSA/software/r ... Update.pdf).After restarting the N9010, I encountered an error as follows:
"LaunchXSA.exe has encountered a problem and needs to close. we are sorry for the inconvenience."
So When I click the "What data does this error report contain?" link, I noticed that it is an system.invalidoperationexception.
So what would be the solution. I lost my Signal Analyzer
Regards
Cengiz EKEN
Regards
Cengiz EKEN
There are several potential reasons for an error message such as what you are seeing. However, rather than trying to explore each possibility and recommending a unique solution for each, it will be quicker to simply perform a Disk Drive Recovery as described in the Getting Started and Troubleshooting Guide (http://cp.literature.agilent.com/litweb ... -90162.pdf ) and then upgrading to A.07.06. You might very well see errors after doing the recovery, but performing the upgrade to A.07.06 should clear those errors.
Be sure to follow the upgrade instructions at http://sa.tm.agilent.com/XSA/software/r ... Update.pdf .
Regards -
