I'm trying to get data out of E4440A through Instrument Web Interface of Agilent Connection Expert. The popped window always shows "cannot display the webpage"
I think the PSA IP config is correct because the same PC can control it through 89600VSA program. I have a agilent ESG connected to the same router and its web interface works fine.
Any idea? I really not to get these data. The floppy disk is not working.
Try to check off the "Use proxy for LAN connection" in the Microsoft Internet Explorer.
