i know that for the 8591E the Option 130 (small band resolution) is available. Is there any way to install this option in the 8591A?
Kind regards,
Jan
Kind regards,
Jan
While the option 130 board will plug into the option card slots in the 8591A, and you could change out the A14 Log Amplifier board with one for an E series (which would be required to route its output to the option 130 board) the 8591A firmware never knew anything about the option. The instrument would not know how to control it, align it, or even route a signal through it.
You also cannot install the E series firmware in an 8591A...
Sorry...
Best regards,
Mike
