We are trying to use multiple Avantek YF87-4067 YIG filters in a multi-channel research experiment.
We are unsure what the requirements are for the heater voltage and current.
When we put what we think would be a reasonable voltage into the heater, the current draw is very high and the YIG becomes so hot we can not touch it. We are reluctant to experiment with the heater voltage very much for fear that we might burn out a YIG.
We believe that the Avantek YF87-4067 may have ben used in the 8563 spectrum analyzer. The frequency range and vintage seems to match. It might also have been used in the 8593. The frequency range is the same with option 026/027.
Can you tell us whether the YF87-4067 was used in any of your spectrum analyzers?
Is there any information available that describes what the heater voltage and current requirements are?
Also, what are the tuning voltage and current requirements?
Thanks for your help.
Ben
Dr. Ben K. Sternberg
Professor, Electrical & Computer Engineering,
Geological & Geophysical Engineering,
and Director, Laboratory for Advanced Subsurface Imaging (LASI)
University of Arizona, MSE Dept., Room 141, Bldg. #12
1235 E. James E. Rogers Way
Formerly known as 1235 E. North Campus Dr.
Tucson, AZ 85721-0012
Tel. 520-621-2439
FAX 520-621-8059
bkslasi@email.arizona.edu
Ben
Tel. 520-621-2439
FAX 520-621-8059
You could use a spectrum analyzer as a down converter, and this way the instrument will control its own YIG and be stable. The PSA or PXA spectrum analyzers both have IF outputs that can be used for this application. www.agilent.com/find/sa
I hope this was helpful -
