We just bought an U3606A, and I have installed all required software.
Connecting USB cable from the unit to WindowXP and have been able to talk to the unit using the provided "Agilent Connection Expert".
But now I am clueless as to how to start a program to control it. I cannot find any clear document explaining how to start, what software to use, etc...
Would someone pls help?
I plan to use TCL for this since all our automation are done with TCL. Is it possible? if not what programming language should I use?
Pls also point out any link that will explain steps as how to get started.
Thansk.
Thansk.
I have been able to get a simple program running, configuring some voltage output.
But when I try to set voltage ramping, the unit keeps beeping with error.
OUTP 0 OK
SOUR:VOLT:RANG 8 OK
OUTP 1 OK
SOUR:VOLT 5 OK
SOUR:VOLT 0 OK
SOUR:VOLT:RAMP:STEP 100 Beeping with error
! VI_ERROR_TMO: A timeout occurred
Visa ErrorCode: 0xBFFF0015 (-1073807339)
SOUR:VOLT:RAMP 5 Beeping with error
I even try to use Agilent Interactive IO and same results.
Pls help.
Appreciate very much.
