Hello all,
I'm a owner of a HP 8591A (with option 001 and 021), but some problems occured a few days ago and i hope that someone here can help me to find out what the problem is and how i can repair it.
Some explanation about the problem: Since a few days the calibration signal is very unstable and also some of the 'BW- correction numbers in the displayed cal data' is out of range.
Because of this, i took the service manual and did some easy calibration, such as the power supply- and Crystal an LC Bandwidth calibration.
After i did this, the BW correction numbers that falled out of range are a little progressed, but not that much that they fall inside the -0,80 and +0,50 range.
Also the calibration signal is still very unstable.
I hope that someone here can help to find out what the problem is?
Thanks in advance,
Marcel.
Thanks in advance,
Marcel.
do you have access to another instrument, (as another spectrumanalyzer or a powermeter), so you can measure the 300MHz cal-output? If so check the outputlevel to see if it's unstable.
Regards
Jens
