Greetings.
Achieve repair power supply problem (A6) HP8563A my thanks to Mike provides schematic diagram. But control of intensity and focus do not work from the front panel. Suspect of A17. The signals A2 controller assembly, is correct in A17 DRIVER DISPLAY CTR I suspect this module, if I can help with schematic diagram of Assembly A17
Part Number 08563-60107.
Thanks
Thanks
Can you check the part number of the A17 Display Driver board you need the schematic for? the 08563-60107 is an A15 RF board...
