8753 interaction between error correction and source power
Question asked by b.d.hall on May 8, 2011
Latest reply on May 10, 2011 by Dr_joel
Is the following behavior expected?
With an active calibration and correction on, I can change the power level (say from -3 dBm to 0 dBm). Then I can turn correction off and the power level is unchanged. However, if I then turn correction back on, I get the error message "CAUTION: HP 8753 SOURCE PARAMETERS CHANGED", and, worse, the power setting changes to -7 dBm.
