I'm using a MSO6034 oscilloscope with segmented mode. Retrieving data from all segments to Matlab works fine, if you loop over the number of segments (['ACQ:segm:index ',num2str(ii)]) followed by read out data (':WAVEFORM:DATA?'). It would be easier to read out all at once, but as stated in a previous topic, this does not work.
However, with the latest version (v5.20) a new option (':SAVE:wav:segm ALL') is introduced. Can this be used to save all segemented data at once and if so how? Does it require local storage at the oscilloscope first, for example?
All suggestions are welcome!
