We have several MSO6014A scopes and really love them. But the one thing that is lacking is a way to save the screen and then later on a PC be able to make time/voltage measurements using on screen cursors. It would be very helpful to have a program similar to Tektronics WaveStar application which provides this capability. Does such a program exist. Too many times we have saved a screen shot of a waveform and then at later date wished we had measured some interesting feature such as voltage or pulse width. Thank you.
one option is a B4610A license, which lets you pull the saved waveform data, in csv or alb format, into the logic analyzer gui, where you can make many measurments: http://cp.literature.agilent.com/litweb ... 7834EN.pdf
free LA sw (second link ~478MB): http://www.home.agilent.com/agilent/edi ... 3:epsg:sud
this migth help:
plug the scope into the lan, grab the IP addy, and shove that into a web broswer... go to web browser control, then remtoe scoep frotn panel. you migth need to update java... it will do that for you. I think, in wavestar, it is mor of a live application... it doesn't work on saved screenshots, does it?
