I'm making a visual basic software to manage an oscilloscope remotely, my intention is to capture two channels and save data to disk.
I use the following code:
With Osciloscopio
.WriteString "*RST"
.WriteString "*CLS"
.WriteString ":Channel1 ON"
.WriteString ":Channel2 ON"
.WriteString ":AUTOSCALE"
.WriteString ":ACQ:MODE RTIME"
.WriteString ":ACQUIRE:SRATE " & s_rate
.WriteString ":ACQUIRE:POINTS " & puntos
.WriteString ":ACQuire:BANDwidth " & band_width
.WriteString ":Timebase:range " & t_adquisicion
.WriteString ":TRIGger:EDGE:SLOPe EITHer"
.WriteString ":RUN"
'.WriteString "*opc?"
'result = .ReadString
'MsgBox "Esta preparado: " & result
.WriteString ":DISK:SAVE:WAVEFORM CHANNEL1,""" & captura.Text & "_1_cap_" & num_cap & """,CSV,ON"
.WriteString ":DISK:SAVE:WAVEFORM CHANNEL2,""" & captura.Text & "_2_cap_" & num_cap & """,CSV,ON"
End With
'*****instructions * OPC? are commented out (I have disabled in my code)
My problem is that some times I get the error message -410 (Query Interrupted). I think you can solve with the instruction * OPC or * OPC? but not use them correctly in my code. Could it be that no time to finish some of the instructions that I have commanded it?
Should I make a loop with *OPC or *OPC? to know if I can continue running the following code?
We also feel the same when I create a directory and change the one created by default, can be for the same reason?
Sorry for my English;
I hope some answers and thanks in advance
With Osciloscopio
.WriteString "*RST"
.WriteString "*CLS"
.WriteString ":RUN"
End With
to a file. Better to do a TER? loop until it returns +! after the :RUN. Then you know the scope has trigger4ed and is
acquiring data. If it is a slow acquisition, you can insert waits to ensure a complete capture. *OPC ensures that
the last command was processed, not necessarily completed.
