Hi folks.
I'm very new to the instrument programming. I'm trying to connect to DSO81204A with GPIB or TCPIP using Matlab and get real-time traces from the oscilloscope. I've found some sample codes for Continuous trace acquisition (sync), Continuous trace acquisition (assync), and Single trace acquisition. This is my sample code:
mxa_ip = '10.11.231.96';
mxa_port = 80;
mxa=tcpip(mxa_ip, 80);
set(mxa,'InputBufferSize',100000);
set(mxa,'Timeout',5);
fopen(mxa);
% Set the data trace format to REAL, 32 bits
fprintf(mxa,':FORM:DATA REAL,32');
% Get the nr of trace points
nr_points = str2double(query(mxa,':SWE:POIN?'));
% Get the reference level
ref_lev = str2num(query(mxa,':DISP:WIND:TRAC:Y:RLEV?'));
% Put the instrument in continuos mode
fprintf(mxa,':INIT:CONT ON');
% Create and bring to front figure number 1
figure(1)
% Create a plot handle, ph, and draw a line at the ref level
ph = plot(1:nr_points,ref_lev*ones(1,nr_points));
% Adjust the x limits to the nr of points
% and the y limits for 100 dB of dynamic range
xlim([1 nr_points])
ylim([ref_lev-100 ref_lev])
% Activate the grid
grid on
% Plot cycle
for i=1:100
fprintf(mxa,':TRAC? TRACE1');
data = binblockread(mxa,'float32');
fscanf(mxa); %removes the terminator character
% Change the plot line data (fast update method)
set(ph,'Ydata',data);
% flushes the plot event queue
drawnow
end
% Disconnect an clean up
fclose(mxa);
delete(mxa);
clear mxa;
I've no problem with connecting and opening the GPIB/TCPIP connection, and setting the data trace format, but when I use query(mxa,':SWE:POIN?') to get the data, it takes a lot of time and at the end my data is empty and nr_points is NAN.
Also I'm looking for a manual for Agilent remote connection commands. (like: :FORM:DATA REAL,32)
I appreciate your help!
mxa_port = 80;
fopen(mxa);
figure(1)
xlim([1 nr_points])
% Activate the grid
grid on
% Plot cycle
for i=1:100
drawnow
end
fclose(mxa);
delete(mxa);
clear mxa;
with this scope model. E.G. the allowable waveform formats are byte, word and ASCII for a DSO81204A.
