Skip navigationLog in to create and rate content, and to follow, bookmark, and share content with other members. Hi! I'am trying to interface MSO7104A digital oscilloscope to my computer usingMatlab. Everything it's okay until i tried to acquire the data from any of the four analog channels.. I can't get the data..this is my code.. i could read or modify everything in the scope. the only problem is acquiring the channels..
%% Create a VISA-USB object.
oscilo = instrfind('Type', 'visa-usb', 'RsrcName', 'USB0::2391::5973::MY48260590::0::INSTR', 'Tag', '');
% Create the VISA-USB object if it does not exist
% otherwise use the object that was found.
if isempty(oscilo)
oscilo = visa('AGILENT', 'USB0::2391::5973::MY48260590::0::INSTR');
else
fclose(oscilo);
oscilo = oscilo(1)
end
% Connect to instrument (me conecto al osciloscopio).
fopen(oscilo);
fprintf(oscilo,':AUToscale');
fprintf(oscilo,'TRIGger:SOURce CHANnel1');
%mido amplitud canal 1
fprintf(oscilo,':MEASure:SOURce CHANnel1');
fprintf(oscilo,':MEASure:VRMS?');
vrms= str2num(fscanf(oscilo));
%Adquirir señales del canal 3
fprintf(oscilo,':ACQuire:TYPE NORM');
fprintf(oscilo,':ACQUIRE:COMPLETE 100');
fprintf(oscilo,':DIGITIZE CHAN3');
fprintf(oscilo,':MEASURE:SOURCE CHANNEL3');
fprintf(oscilo,':MEASURE:FREQUENCY?');
fre=str2num(fscanf(oscilo));
fprintf(oscilo,':WAVEFORM:SOURCE CHAN1');
fprintf(oscilo,':WAVEFORM:FORMAT WORD');
fprintf(oscilo,':WAVEFORM:POINTS 1000');
fprintf(oscilo,':DIGitize CHAN1');
data = query(oscilo,':WAVEFORM:DATA?')
waveform_size=5000;
fprintf(oscilo,':WAVEFORM:PREAMBLE?');
pream=str2num(fscanf(oscilo));
fprintf(oscilo,':RUN');
fclose(oscilo);
Thanks!!!Fernando.
Does your 'query' know how to read a BINBLOCK format return?; because that is what you are going to get.
Try chaning the format to ASCII.
