I cannot seem to successfully run any of the USB tests in the application. For example, for the Host Low Speed Signal Quality Test yields this error:
High speed yields a similar error.
The probes are set up properly, and I don't see what being unable to find a web page has to do with setting them up incorrectly either way. Uninstalling/reinstalling the test app does nothing.
A side concern: The website says the version is 3.40.0006, and so does the installer. The about page, however, reports itself as 3.40.0005.
Have you looked to make sure that the file in question is actually there? All of the compliance tests provide html output, and use html input files to provide the framework for that output.
