I set the wavegenerator on my DSOX 2002A to
SIN, 10 Hz 300mVpp
I measure with the scope
Measurementfunction tells me Pk-Pk(1) 593 mV
Now i change the generator setting to Highlevel/Lowlevel
High is set to 150 mV
Low is set to -150 mV
I would expect 300 mV now.
Is is a bug or my mistake? Where should i report the bug, if it is a bug?
Kind regards
SIN, 10 Hz 300mVpp
Kind regards
If it is set to 50 Ohms, and you are connecting to a 1M input on the scope, then you should see about twice what you expect, which is what I think is happening. If you change either impedance, so that they match, you should see the correct values.
See my response to "How to connect the function generator with the laod? "
Al
