I am new to DSOX2024A built in function generator. I want to connect a load to the wavegen output. I set the wavegen as PULSE wave-250Hz-5Vpp-width(2ms). when I check this output with the DSO, I could see the perfect PULSE wave-250Hz-5Vpp-width(2ms). But when I try to connect the load to the wavegen output. I couldn't see the pulse wave in the DSO I could see only the fully OFF signal(0V), I am using the Agilent N2863B 300 MHz PASSIVE PROBE.
Please suggest me the best way to connect the function generator to the load.
Output impedance 1M, no load - Full voltage
Output impedance 1M, 50 Ohm load - Very small voltage
Output impedance 50 Ohm, no load - Double voltage
Output impedance 50 Ohm, 50Ohm load - Full voltage
Al
