HI,
What I want to have is similar to segmented mode acquisition but manually; acquire a waveform and append it to scope's memory.
It seems that ":WMEMory<N>:SAVE" simply overwrites the memory with the current waveform.
Do someone knows how to append current waveform to previous ones if it is possible?
I could use segmented mode but I need to control each trigger instead of getting some given # of triggers blindly(?).
Best regards,
Yun-Ha
Best regards,
Yun-Ha
I don't understand why you can't use Segmented Memory mode. That mode allows you to control how may segments (triggers) you capture, and how deep each one is. They are time-correlated, and you can play them back.
Please describe what you are trying to do, and we can see if there's a solution.
AG
