Hello everybody!
I am using InfiniiSim to compensate the effects of an amplifier with 60 dBs of gain. I obtain the transfer function shown above.
![Image]()
I use a hardware scale of 600 mV and a display scale of 350 uV. After the de-embbeding process I obtain the signal in time domain sown above (the same before aplying Infiniisim but smaller). The display scale shows the signal has values of several uV.
![Image]()
However, If I save the simulated waveform using "Save->Waveform->Channel1" I obtain that the tension values are -1v, 0v, or +1 v. Why do I obtain this? Because, displays shows one thing but we are saving another different thing...
I would appreciate any idea
Thank you in advance
TYou are doing something very wrong. The transfer function does not look right at all. You should refer to the help menu that describes the InfiniiSim application you are using. If you are still having problems, I suggest you contact your Agilent represenative or a contact center for additional help. In the US, you can call +1 (800) 829-4444. Outside the US go to www.agilent.com and select contact us.
