I am using a DSO5054A scope that is connected to my computer via a USB cable. I have both IntuiLink and IOLibrariesSuite installed. I am using Intuilink in order to obtain the data of the waveform that I'm measuring but as I can see from the plot in the IntuiLink window, the data is often incomplete, as if some samples are missing. How can I fix that? (I need to save about a second of a 75KHz signal).
Thanks ahead
Thanks ahead
