I've been having this problem for years on different installs and PCs. As far I remember it was present in 2.1.13.0 and is still in 3.7.0.0. To reproduce it just grab four (or more) scopeshots, select "Print Preview" from a File menu, select 4 scopeshots from "Print Settings", choose 4 plots per page and finally click on "Preview". From time to time it will not show 4 scopeshots and if you try to do anything to fix it (by repeating some of the previous steps) it will crash, see the attached screenshot. The probability of it crashing increases with the number of scopeshots I get and the number of printing operations.
Thanks a lot.
tomasz.
Thanks a lot.
tomasz.
