Hi all,
I'm working with a MSO6052a oscilloscoop. I need an accurate acquisition and i found a way to do this in the programmers guide for the 6000 series oscilloscoop. My scoop is doing something strange when i'm trying to access the :WAV:POIN:MODE and :SYST:PREC ( and a few others ) parameters . He is saying "undefined header" on the oscilloscoop screen. I double checked it but there is nothing wrong with the command ( i'm using LabVIEW 7.1 ). The firmware revision of the scoop is 02.02. I don't know if this is the most resent revision... I hope somebody can help me.
PS I used the ":WAVeform:POINts:MODE" page of the programming guide
Joren Moelans
Joren Moelans
"Undefined header" is usually the scope's response to a syntax error in the incoming data stream. The old firmware
did have some GPIB issues.
