Hi, every Engineers,
Now I am simulate a MBOA UWB Transceiver, I just focus on the RF except the baseband. So I don't know how to generate the signal. Now I have set up the architecture of receiver without the input signal, who can help me to build the signal source, thank you very much.
Check out the link below. There is a reference to the Signal Studio software you can use to generate the signal, and the generators that can be used with the software. There are also links to the analyzers and VSA software you can use to do the analysis of the transmitter.
There is also a link near the bottom of the page to an Application Note that does a good job of discussing the issues and measurement techniques associated with the Ultra-Wideband Communication
RF Measurements.
http://www.home.agilent.com/agilent/ind ... mpid=95192
