Hello I have a big Problem wit a DSO3062A and the new Firmware and Scopeconect Software (Firmware=04.02.10 / Scopeconect=1.1.26)
If i use the Software (via USB) and disconect from Scope i cant controll it with the Knobs on the Scope i need to switch it off and on again all the Time
it shows me still the red rmt sign on the screen even after the scopesoftware was closed and the usb cabel is unpluged
this problem i dont had befor with the older Firmware
so may be anyone could send me the old firmware or anyone know a fix for this problem
when doing a disconnect. You can return to local mode by pressing
the Local key(Force under the Trigger section) after ending the
DSO3000 session. No need to reboot.
