hi everybody
I have an HP54600A oscilloscope with DB-25pin connector and new printer that does not accept the 25-pin connector . any suggestion how to connect the two? . Also I am looking to connectthe scope to my PC.
I am not familar with progrmming just a normal electrician.
Thank you for any help
You can communicate with your 54600A via GPIB or RS-232C if you have the corresponding interface module attached to the back of the instrument. Below is a link to to the Programming Guide for the 54600A Oscilloscope:
http://www.home.agilent.com/agilent/red ... 6898050.00
