Can we generate power profile directly from a measured signal using the DSO 8064A, or we will have to take the measured signal data and calculate from it the power delay profile using some other technique (squaring the signal magnitude).
In one such scenario a square wave detector was used in front of the Oscilloscope so that the waveform shown by the oscilloscope was actually the power profile and not the signal in time domain.
Hope i have delivered my query properly.
Regards
Regards
We have the U1882A option that automates power measurements. You can take a look at:
http://cp.literature.agilent.com/litweb ... 7835EN.pdf
and see all the power measurements that this feature has to offer. If you need further help or clarification just post it in this forum.
Best regards,
edgardog
