In which USB test is the 34401A Multimeter used?
Is it under the control of the application software on the scope?
Thanks for your help.
On the go testing require the 34401A. But for the J test, the K test and the SE0_NAK test a simple handheld multimeter with 0.1mV at 400mV would work just fine as well. Since Agilent doesn't make these, simply recommending a 34401A would do all tests. Handheld multimeters - since a lot of customers already have one of these at their desk and for those who don’t need on the go testing, this would be a cheaper solution
