Hello everybody!!
I'm using Infiniisim to compensate the effects of some cables and a passband filter of my signal. The problem is that if I compensate also the rejected band (from 0 up to 3 GHz), I obtain a increment of more than 50 dB in such rejected band. Sould I compensate only my "band of interest", for example from 3 up to 4 GHz and not from 0 to 4 GHz?
Thank you very much
Thank you very much
I have created passband filters and comb filters by directly manipulating the .tf2 files with no problems. Please post pictures or other info that might help me figure out what's going wrong...
AG
