I am using Agilent scope and N5382A active-probe.
I am trying to build a spice model to that probe according to the following guide:
http://cp.literature.agilent.com/litweb/pdf/01168-92002.pdf
The guide present a spice model which has a voltage sources (vsminus & vspluse). what are these voltage sources?
the voltage source:
vsminus 16 2 ACMag=sweep(1,0)
vsplus 1 16 ACMag=sweep(1,1)
I believe this V-source is iligal spice source. with what should I replace these lines??
this is the spice model from the guide:
Thanks.
the voltage source:
Thanks.
