I upgraded an Infiniium to software version 05.71 and a tab labled "Scale" appeared on the screen.
It is always there and takes up a large amount of screen space, even when no measurements are active.
How can I make it go away?
The on-line help says that it only appears when some other measurement is active, but that does not seem
to be the case.
to be the case.
The scales tab is always there. The scales tab shows the vertical and horizontal settings. There is no way to make the scales tab go away.
