These are no longer supported. I have a 54845A that powers on fine, passes all self tests and the self cal but shows "fine interpolator error service required" . The scope seems to work correctly. Any idea what could be causing this? Are there any CLIPS available for the 54800 series units? If i understand correctly the interpolator is part of the ADC on these. Any help would be great!
Len
Len
Hi Len,
I can't answer your question, but if you know the problem lies with one of the A/D converters, I have some tested ones for sale on Ebay.
Item 220703188163. They rest in sockets, which makes for a fairly easy swap. AFAIK, there is no CLIP for these scopes.
Good luck.
Jay
