DSO3062A - EMC problem
Question asked by Datong on May 22, 2009
Latest reply on May 28, 2009 by dnt
We have a couple of DSO3062A scopes that seem to have a EMC issue -they radiate at ~1.5GHz.
This has caused problems with the GPS receivers in the systems that we are trying to measure.
On a 2 turn loop the signal is at ~-35dBm around the screen area.
This is quite sufficient to block our GPS receivers. As soon as the scope is switched off, the GPS re-aquires instantly!
Thought you should know.
