Hallo,
Sw:
Agilent Infiniium Oscilloscope 05.40.0000
Agilent IO Library Suite 14.1
Problem:
Saving in any waveform format including digital channels.
The software escapes with an error message.
There is a problem since I shut down the system yesterday and I can`ta save the digital channels today. When I save only analog signals, there is no problem.
There are two cases which appear:
1. I want to save the data as a new file, I will get the error message (which you can see in the attachment) and the software escapes.
2. I want to save the data as an existing file, the software escapes immediatly.
I tried to update the software (previous version 05.30.0004) without a change of described behavior. Furthermore I disconnect the cable on digital channel and tried to save a waveform including the digital channels with the same error message.
I suppose that the software works incorrect because of attempting my last method of resolution.
Have you any idea how to solve this problem?
best regards,
Mark
Sw:
Problem:
best regards,
Mark
The software doesn`t escape when unchecking the box "include scale factors". The waveform can saved by the user, but this seems a bad solution because of excluding the scale factors.
