Skip navigationLog in to create and rate content, and to follow, bookmark, and share content with other members. Hi, I am trying to get data out of the HP16500b without success. I can control the analyzer and view setting but cannot transfer data. Here is my code with what I have tried and the results
GPIBOut("SEL 5")
GPIBOut(":DBL UNP") 'want data unpacked
'hpVNA.SetBufferSize(Ivi.Visa.Interop.BufferMask.IO_IN_BUF, 4 * 1024 * 1024)
GPIBOut(":SYST:DATA?") ' Ask for trace dump
'********* Test cases
TRACE.Add(hpVNA.ReadIEEEBlock(Ivi.Visa.Interop.IEEEASCIIType.ASCIIType_UI1))
' 16500B Query Inerupted on next command - 'VI_ERROR_TMO: A timeout occurred
'TRACE.Add(hpVNA.ReadIEEEBlock(Ivi.Visa.Interop.IEEEBinaryType.BinaryType_UI1))
'TRACE.Add(hpVNA.ReadIEEEBlock(Ivi.Visa.Interop.IEEEASCIIType.ASCIIType_Any))
'TRACE.Add(hpVNA.ReadIEEEBlock(Ivi.Visa.Interop.IEEEASCIIType.ASCIIType_BSTR))
'TRACE.Add(hpVNA.ReadIEEEBlock(Ivi.Visa.Interop.IEEEASCIIType.ASCIIType_UI1))
' No Error on 16500B
'TRACE.Add(hpVNA.ReadString) ' "#801780090DATA "
'myStr = hpVNA.ReadString ' "#801780090DATA "
'TRACE.Add(hpVNA.ReadList(Ivi.Visa.Interop.IEEEASCIIType.ASCIIType_Any))
' No Error on 16500B - Couldn't interpret I/O data as single number.
'TRACE.Add(hpVNA.ReadNumber(Ivi.Visa.Interop.IEEEBinaryType.BinaryType_UI1))
'TRACE.Add(hpVNA.ReadNumber(Ivi.Visa.Interop.IEEEBinaryType.BinaryType_I4))
'No Error on 16500b - Unexpected I/O termination or couldn't convert list item # 1 to long/integer/byte format
'TRACE.Add(hpVNA.ReadList(Ivi.Visa.Interop.IEEEBinaryType.BinaryType_UI1))
' Query Interupted on 16500B - Couldn't interpret I/O data as single number.
'TRACE.Add(hpVNA.ReadNumber(Ivi.Visa.Interop.IEEEBinaryType.BinaryType_I2))
I can get the first header if I am looking for a string back, but if I am looking for data I get nothing? Any help would be appreciated.
