Hello Everyone,
I compiled and linked a VISA program in C++,6.0 environment, with 0 error and 0 warning. But, while excution begins, about 5 errors came
that says: unresolved external symbol _viClose
unresolved external symbol _viprintf
unresolved external symbol _viStatusDesc
unresolved external symbol _viopen
unresolved external symbol _viOpenDefault
The program is to interupt a DC power supply Egilent model 6654A and the GPIB card is 82351A GPIB interface card. The interuption is about 220ms. some one please help me to resolve such problem.
The C++ code is:
#include <visa.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <windows.h> // only used for Sleep function
void main () {
// These variable are neccessary to initialize the VISA system.
ViSession defaultRM, vi;
ViStatus status;
char statusDescription[128];
// This variable is to be used for GPIB communication
// GPIB0 is the VISA name of the interface
// The instrument is at address 5
char IOaddress[] ="GPIB0::5::INSTR";
// The default resource manager manages all of the overhead required for VISA
viOpenDefaultRM (&defaultRM);
// Opens a communication session with the instrument at address 5
status = viOpen (defaultRM, IOaddress, VI_NULL,VI_NULL, &vi);
if (status!=VI_SUCCESS) {
viStatusDesc(vi,status,statusDescription);
printf("Error on viOpen: %s \n",statusDescription);
exit(EXIT_FAILURE);
// Initialize device
viPrintf (vi, "*RST\n");
//Set the voltage
viPrintf (vi, "VOLT 28\n");
//Set the current
viPrintf (vi, "CURR 5\n");
while(1){
//Turn Output On
viPrintf (vi, "OUTP ON\n");
// We need to wait 220ms
Sleep(220);
//Turn Output Off
viPrintf (vi, "OUTP OFF\n");
Sleep(220);
// Close session
viClose (vi);
viClose (defaultRM);
The C++ code is:
#include <visa.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void main () {
ViStatus status;
exit(EXIT_FAILURE);
//Set the voltage
//Set the current
while(1){
//Turn Output On
Sleep(220);
//Turn Output Off
Sleep(220);
// Close session
viClose (vi);
Is IO libs installed on the computer you are running the executable on? Is it the same version as the one you compiled (shouldn't matter, but just in case)?
please advise me soon.
Are you running the program on the same computer that you use to compile the program?
Agilent VISA User's Guide:
http://cp.literature.agilent.com/litweb ... 6135EN.pdf
regards,
