I'm trying to figure out this Matlab API interface. I'm looking at the Matlab example and the help files, but I'm not getting what I need. I ran the example code and was able to grab the the time domain data.
I need to be able to grab data such as demodulated data from OFDM Syms/Errs window, raw data, and be able to invoke triggers.
I looked through the help files, and I'm not getting what I need from documentation on the Matlab API to solve these problems.
Are there are places where I can find more examples or more documentation on how to do this?
Thanks.
Thanks.
I am the support engineer for 89600 VSA and the best way to contact us is through sad_support@agilent.com.
The first thing that you need to familiarize yourself with is the COM Object Model, see the attachment for help in finding this from the help section. The Object Model is also available in pdf format under the C:\glacier_cd\manuals\.
We have a Macro that you can run to retrieve Table Values, see Utilities>Macros...>TableVals. I assume you have looked at our Matlab examples. I also have a number of other examples in VB that might be useful to you, but the program is too big for me to attach here. You will need to contact me through email.
Finally, if none of these will help you, I will be more than happy to look at your program snippet.
Best Regards,
Mohammad
