I get the following error when trying to install the Agilent IO Libraries Suite 15.0:
"Error 1920.Service Agilent IO Libraries Service (AgilentIOLibrariesService) failed to start. Verify that you have sufficient privileges to start the services."
I am an Administrator of my PC (Dell 390, 2GB, XP SP2). I tried to manually start this service in the Services Console, but then I get the following error:
"Could not start the Agilent IO Libraries Service service on Local Computer. Error 1068: the dependency service or group failed to start."
I am forced to cancel the installation.
Anybody have an idea what's wrong, and how to fix it?
PS - Agilent should have an instrument-independent forum for these software and connectivity questions.
Thanks.
Thanks.
which must be running or the Agilent service can't be started. I can't
recall the names of these, but perhaps an Agilent IO Lib expert will chime
in here. Otherwise, call their tech support and they'll tell you which
services must be allowed to run.
