Problem with getting access to web server in MSO6014A
Question asked by AlMa1975 on Oct 2, 2007
Latest reply on Oct 2, 2007 by AlMa1975
Hello together,
I have the following problem:
When I connected my MSO6014A to my companys network I decided that it would be a good idea to protect it with a password.
This worked fine but now a dialog box appears where a login name and a password is prompted. The password is well known by me but I never set any login name - which one should I use (a empty field, admin, guest anonymous and so on did not work)?
I did not found any hint in the documentation - I can reset the password but then the oscilloscope is again not protected!
Thank you for your help!
best regards
Alexander Matern
