I have used some scopes in auto repair .
Now have been looking more , because of use in RF , Ham Radio , work / hobby .
I picked a load of test equipment , among it is a HP 54110D 1GHz digital scope , also a HP 54300A probe multiplexer - with about 9 probe modules .
I have been searching for info / accessories [ no probes , except one module has a permanently connected probe ] .
Seems like I can find info for just about every other scope , but this one , manual .
Any leads would help ?
Thanks John
Thanks John
The 54300A was a probe multiplier. It had two output channels with a 1GHz switch to switch between the probes. You could mix and match the probe pods as you wished. You could operate it manually or over remote control. The intended use model was remote control.
I hope that answes your questions.
