I want to acquire a signal with 200MHz of bandwidth, centered at 3,5 GHz. If I leave the scope in a single-shot mode, may be the scope will trigger with any signal in all its bandwidth but I want that it waits until a signal centered at 3,5 GHz.
My question is...is it possible to do some kind of filtering in the trigger or a kind of selection in frecuency before the scope starts to acquire the signal?
Thank you everybody.
You can use, for example, the channel A to see the signal and the channel B with a band-pass filter as the source of trigger. An appropriate filter for your purpose could be the Mini-circuits VBFZ-3590+:
http://www.minicircuits.com/pdfs/VBFZ-3590+.pdf
