Trigger:Enable External Device
Question asked by jane on Mar 25, 2009
Latest reply on May 29, 2009 by sdwood
I want to check the  External Device enable box in the I/O 2 Trig Out tab, in the Trigger dialog box.  Is the command: control:signal:trigger:outp true  ????
One model of PNA has a Trigger dialog box with tabs including:
Trigger
External Trigger
Aux Trig 1
Aux Trig 2
While the E836X and PNA-L models, which I use, have a Trigger dialog box with tabs including:
Setup
External
I/O2 Trig Out
My question is, are all the SCPI commands the same for both models, and is that the right command?
Thanks a lot!
