I am sorry for my ignorance here but I am relatively new using the Agilent DS3202.
There is a USB module installed and i have had no problem using the Scope connect software.
My problem is that I need to store the testing I do for a long period of time (a few seconds).
I have tried to use the sequence modes (capture, play-back and storage) but I am not exactly sure how they work?? I have just fiddled so far and have found that the frames which result, split the signal I am interested in into two frames some of the time.
How would I go about getting an entire test session into one data file so I can process it later on a PC??
Any help is greatly appreciated.
The sequencer's purpose is to provide a kind of visual playback of
long time period. The sequencer memory is not accessible to a
user and the frame capture parameters are not defined.
The maximum memory you can access is 4000 points. But if you are
trying to capture several seconds of data the scope will be in ROLL
mode limiting you to 1200 points.
