Undersatnding of Balance and Unbalance signal Measurement
Question asked by jaz on Jul 14, 2011
Latest reply on Jul 14, 2011 by Dr_joel
Dear All,
Taking an example of Differential signal to single ended signal, how does the PNA the gets the measurement data. In other words, If i use modulation power of 2dBm, what as input differential signal, what is the voltage it transmitted to my load (assume 50 ohm). What is the resultant voltage output out from the single ended channel? What would be the resultant phase data at my single ended channel assuming load is ideal transmission line.
Looking forward if anyone can help to clarify. Thank you in advance.
