Brand: Agilent
Model: E4411B
Type: Spectrum Analyzer
Issue: Dim Screen
Hello, I have a Agilent (HP/Agilent/Keystone) E4411B Spectrum analyzer. The display is very dim when the brightness is at maximum. How is this corrected?
James
Brand: Agilent
Model: E4411B
Issue: Dim Screen
James
The menu and graticule is yellow. So it needs both backlights replaced. Anyone have info about the cost to replace them?
James
On Friday, December 18, 2020, 5:35:19 PM PST, dhamilton <moderator_forums@keysight.com> wrote:
#yiv2552008319 * #yiv2552008319 a #yiv2552008319 body {font-family:Helvetica, Arial, sans-serif;}#yiv2552008319 #yiv2552008319 h1, #yiv2552008319 h2, #yiv2552008319 h3, #yiv2552008319 h4, #yiv2552008319 h5, #yiv2552008319 h6, #yiv2552008319 p, #yiv2552008319 hr {}#yiv2552008319 .yiv2552008319button td {}
Keysight Community
Re: Hello: I have a Agilent E4411B Spectrum Analyzer. The display is dimmer than I think it should be. I can adjust it up and down, but it is still very dim. Any suggestions on how to correct this?
reply from dhamilton in Signal Analyzers - View the full discussion
If it has a yellowish tint or darkening on the ends the CCFL backlight is dying.
Reply to this message by replying to this email, or go to the message on Keysight Community |
Start a new discussion in Signal Analyzers by email or at Keysight Community |
Following Re: Hello: I have a Agilent E4411B Spectrum Analyzer. The display is dimmer than I think it should be. I can adjust it up and down, but it is still very dim. Any suggestions on how to correct this? in these streams: Inbox |
This email was sent by Keysight Community because you are a registered user.
You may unsubscribe instantly from Keysight Community, or adjust email frequency in your email preferences
What does it cost to replace the backlights?
J
On Friday, December 18, 2020, 5:56:23 PM PST, dhamilton <moderator_forums@keysight.com> wrote:
#yiv6554390011 * #yiv6554390011 a #yiv6554390011 body {font-family:Helvetica, Arial, sans-serif;}#yiv6554390011 #yiv6554390011 h1, #yiv6554390011 h2, #yiv6554390011 h3, #yiv6554390011 h4, #yiv6554390011 h5, #yiv6554390011 h6, #yiv6554390011 p, #yiv6554390011 hr {}#yiv6554390011 .yiv6554390011button td {}
Keysight Community
JKL Components Corporation CC26153 |
JKL Components Corp. CC26153
