Momentum - Dielectric constant vs frecuency issues
Question asked by simozz on Nov 9, 2020
Latest reply on Nov 12, 2020 by volker_muehlhaus
I am making some simulations for a stripline filter in Ku band (17.2 GHz) using a DiClad 880 Substrate.
Dielectric constant variation should be as plotted below
from https://rogerscorp.com/-/media/project/rogerscorp/documents/advanced-connectivity-solutions/english/data-sheets/diclad-series-data-sheet.pdf .
However I see that in layout simulation the dielectric constant variation is significantly greater.
For example, the following is a plot of the filter response from schematics:
while the next one is the layout simulation:
To center the pass-band at 17.2 I have to manually tune the dielectric constant from 2.2 (schematics SSub) to 1.81 (layout substrate).
Could someone explain such a huge variation vs the datasheet plot ?
Thanks.
Simon
