COM programming command to change the output power
Question asked by shravan.shirodkar on Oct 21, 2010
Latest reply on Nov 29, 2010 by dtbespal
I have been using using the PNA 8362B and I am setting it up and acquiring data through a COM program written in MATLAB. I would like to know the command  to set/change the output power. By default, it is 0 dBm and I would like to increase it. Say, if I am measuring S21, I want more power to go out of Port 1. I tried chan.TestPortPower, but it gives an error, unrecognized or something like that. I get the same error even when I tried to use it on the PNA N5242A.
Can you please suggest a way to change the output power level?
Thank you,
Shravan
