Does anyone know if a verification data disc that comes with a Verification Kit and is labelled for an HP 8720 can be used in an HP 8510C?
The HP 8510C manual states that this can be a cause of verification failure, but I would like to understand the cause and if conversion could allow the use of such a data disc.
Any info is welcome.
Best regards,
Job
PH4AS
No, you cannot use the 8510 disk on the 8720 series. The file structure and data specifications are different.
When you send in your kit, ask for a 8510 disk also.
