using .png file format. Our UXA (N9040B) provides poor resolution screen capture output files.
If you are saving the image, then transferring it to a PC, try using the following: HCOP:SDUM:DATA?
It just takes the one step and sends the screen capture back in binblock format. Attached is an example of what I get.
If you aren't getting anything like this please send an example of what you are getting.
Best regards,
Mike
What command are you sending to get the screen capture?
